Fuel Injectors?! Yellow? Ford?
Old Feb 10, 2020 | 11:06 PM
Frank4's Avatar
10-4. So there isn’t an upgrade option for the Bosch motors?
Old Feb 11, 2020 | 08:49 AM
Alex_M's Avatar
Correct. I researched using some 24# GM injectors and switching to a larger BMW MAF housing to increase your headroom if you were increasing your airflow considerably, but frankly it's just not worth the effort with these motors. You'd have to do a major port job on the heads and intake, and install bigger valves along with a larger throttle body and cam to require the upgrade.
Old Jul 7, 2020 | 07:24 AM
JUKE179r's Avatar
I could have sworn also that someone on here (?) had used 19# Ford Mustang injectors on their Bosch/Thor engine.
I tried a search but can't find who it was.
Old Jul 8, 2020 | 12:56 AM
PalmettoDisco's Avatar
Comparison chart injectors
From a previous post.
Compare the Bosch Ford F6VE (19#)
to the Bosch 0280-155-746
Identical specs across the board.
Old Jul 8, 2020 | 01:57 AM
JUKE179r's Avatar
Cheers @PalmettoDisco !
Are the stock injectors on the Thor engine a single orifice or quad? Kind of late but going by that Stan Weiss page I guess I purchased the correct replacement Bosch injectors since they are tannish yellow with quad orifice #0 280 155 787.
The specs on my -787 are a bit different than the -746 and F6VE injectors...
Old Jul 8, 2020 | 04:50 PM
Alex_M's Avatar
Stock injectors are quad orifice if I remember correctly.
TRIARII
Dec 10, 2016 02:58 PM
humroot
Nov 30, 2014 12:09 PM
jdracersc
Jun 13, 2011 08:36 PM
modem7890
Feb 11, 2008 09:31 AM
