fuel leak fron spark plug
Old Oct 21, 2017 | 02:50 PM
clarence1981's Avatar
Default fuel leak fron spark plug
hi i was thinking of buying a 2001 land rover discovery but the seller says it runs good everything work it only has 140000 miles but there is fuel leaking from the spark plug how do i fix this
Old Oct 21, 2017 | 03:20 PM
Alex_M's Avatar
...fuel doesn't travel through the spark plug. There is no way that's possible unless a cylinder is full of fuel (unlikely unless there's an injector stuck open) and the spark plug is loose enough to allow fuel through (more unlikely)
Sounds like the seller doesn't know what he's talking about. Id take that to mean he also doesn't know what he's doing in regards to maintenance. Just my 2¢
Old Oct 21, 2017 | 04:28 PM
Externet's Avatar
If by some reason is gasoline, everything will catch fire soon.
Old Oct 22, 2017 | 07:08 AM
mollusc's Avatar
It's possible that the seller is confusing the injectors with the spark plugs, in which case it's probably just an o-ring that needs replacing. But that's just a guess.
Old Oct 22, 2017 | 02:39 PM
jfall's Avatar
Haha.
That is probably antifreeze
Need head gasket.
Old Oct 22, 2017 | 02:42 PM
jfall's Avatar
Don't buy a Discovery up to year 2004.
You will be sorry.
Get a 2003 Range Rover. Better engine.
Get a 2005 or newer Discovery.
You can afford it.
Pay more now for 2005 or newer discovery.
Or cheap out and get a 2004 or older Discovery.
You will be very very sorry.
You will pay a lot more later in Headgaskets and towing charges too.
Old Oct 22, 2017 | 03:24 PM
Alex_M's Avatar
I highly disagree. In four plus years of ownership I've head to do head gaskets once (shortly after buying) and I have never been stranded in it. I'm the furthest thing from sorry I bought it and I wouldn't replace it with anything else. And that's me saying that using it as my daily driver.
Don't get me wrong, its a labor of love and I have to stay on top of maintenance, but I think it's every bit as reliable as the 08 Silverado I had as long as its properly maintained.
OffroadFrance
Feb 26, 2015 10:35 AM
gRover Cleveland
Jun 28, 2012 09:41 PM
joevice
Jul 23, 2010 09:15 PM
gmutis
Jan 6, 2009 04:30 PM
Tvdmtac
Sep 15, 2007 08:51 AM
