Fuel leak at Tank
Old Nov 24, 2025 | 04:32 PM
Discoidiot's Avatar
Default Fuel leak at Tank
I've got smell and fuel dripping from the gas tank on the D2, so I've got a few questions for the Wise Old Men here:
1) Is there a common issue that I should be ready for?
2) Is it easy enough to pull up the carpet in the cargo area to look from above? OR, should I just look to drop the tank to really see what's going on. I'm hoping the Terra Firma tank guard comes off easy.
3) Where do you like buying parts for anything fuel tank related
Thanks all
Old Nov 24, 2025 | 10:22 PM
disco96sd's Avatar
likely a leak from the breather tube
likely a perished fuel pump seal on top of tank
Old Nov 25, 2025 | 12:29 PM
Discoidiot's Avatar
Follow up questions -
If replacing fuel pump seal, with 150k miles, should I look to replace fuel pump, or just change the filter since I'll be in there? Recommended replacement parts?
Replaced a seal on another Disco without proper tool, is there a non-expensive tool for this so it's not such a bear?
Old Nov 26, 2025 | 03:24 PM
Harvlr's Avatar
If it's the seal I'm thinking of, a brass drift and hammer (there probably is an official tool though).
mln01
Oct 30, 2024 06:10 AM
Alex von Staffeldt
Defender
Dec 5, 2017 02:22 AM
MTboggs
Apr 16, 2017 07:41 PM
dchyun
Oct 19, 2006 04:20 PM
Alfapat
Jan 2, 2006 06:42 PM
