Fuel in oil? Ticking, knocking. This thing is driving me nuts! Help!
Old 01-26-2018 | 08:22 PM
Alex_M's Avatar
Are you throwing any codes? I had this issue when my truck was parked. It only got ran about once every couple of weeks and I didn't have any O2 sensors installed (no exhaust, only headers).
Bad O2 sensors might be making it run rich enough to wash the cylinder walls and get into the oil. I also second checking your injectors. Sometimes they'll throw an injector code. I think these are the two most likely options.
Old 01-27-2018 | 03:34 AM
The Deputy's Avatar
Originally Posted by Sixpack577
And not to be captain obvious, but I would stop driving it.
These things usually tick for one reason or another anyway, but if there's gas in the oil, that gas is washing all the oil off of cylinders, bearings and the entire engine.
Which means little to no lubrication, and can ruin an otherwise good engine.
This^^^
Stop driving it until you figure out how/when fuel is getting into crankcase, and change oil and filter now. Fuel is not something you want in your crankcase. If it is that abundant, now, that could be what is leading to the "tick". Poor oil pressure, since thinner oil makes it hard for the pump to create pressure.
Do a quick check with a vacuum gauge (look for good vacuum reading and steady needle), pull plugs and inspect (marking location), and do a compression check. And have the codes read.
Good luck,
Brian.
Sixpack577 (01-27-2018)
Old 01-29-2018 | 06:12 AM
pburckhalter's Avatar
5th Gear
Whelp, my motor is completely shot. Thanks for all the advice. Now I'm contemplating doing an ls swap
Old 01-29-2018 | 07:28 AM
Alex_M's Avatar
Care to tell us exactly what's wrong? Both for our own curiosity and for future readers?
Old 01-29-2018 | 07:50 AM
5th Gear
20 psi compression on cylinder 2(fuel soaked plug)Pulled the oil pan and there were metal chunks in panI'm not sure to the culprit yet but I'll try to post my findings once I pull the motor (hopefully this weekend)
Old 01-29-2018 | 07:57 AM
Alex_M's Avatar
Cool. Thanks
Humdinger
10-18-2016 05:05 PM
EstorilM
03-11-2016 06:33 PM
john65b
10-10-2013 05:00 PM
wrongway1
08-22-2012 07:05 AM
whatismyusername
08-18-2011 12:52 PM
Quick Reply: Fuel in oil? Ticking, knocking. This thing is driving me nuts! Help!
