Fuel Pressure Tester Schrader fitting
Old Apr 22, 2021 | 01:53 PM
Motorhead1's Avatar
Default Fuel Pressure Tester Schrader fitting
I have searched and searched, and I can't find the part number or name of the adapter needed to use my standard fuel pressure gauge on the disco? Do I just need to rent one of those large fuel pressure test kits from the parts store? Thanks in advance.
Old Apr 22, 2021 | 02:48 PM
XRAD's Avatar
it's a bosch injector rail so isn't it a standard size? these rails or variants were used on many vehicles...
I just ordered a pressure kit of amazon that comes with several fittings...will see if any fit...
Old Apr 22, 2021 | 03:04 PM
Motorhead1's Avatar
It doesn't fit the "standard gauge"? Maybe you have to use an adapter to use the gauge to all jobs? idk....Maybe that's my problem..lol
Old Apr 24, 2021 | 03:15 PM
XRAD's Avatar
the amazon kit small fitting fit. correct thread n pitch, but a ID a hair too big, so loose for first few turns....probably just get a bosch fitting for the valve. rest of kit was fine...30$
MIKKUPPA 0-140PSI Universal Fuel Pressure Tester Kit
Old May 12, 2021 | 12:25 PM
Motorhead1's Avatar
I went to two local parts stores and looked at their fuel pressure gauge rental kits, neither of them had a fitting/adapter to fit the disco. We measured the thread, and it looks to be M12 x 1.75. I can't find an adapter online. Autozone had a larger kit available with supposedly a lot of different adapters, but it was out for rent yesterday, the kits I got to look at resembled the kit in this link. So I'm still on the search. I wish someone could post a link that is 100% the part I need. I don't want to buy another fuel pressure gauge unless I absolutely have to in order to get the adapter I need.
Here's the link to the pressure kit XRAD recommended.
https://www.amazon.com/MIKKUPPA-Universal-Pressure-Injection-Systems/dp/B07WWT8K5Z/ref=sr_1_1_sspa?dchild=1&keywords=MIKKUPPA+0-140PSI+Universal+fuel+pressure+kit&qid=1620839525&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFBTjQ5V0szVEpMSEUmZW5jcnlwdGVkSWQ9QTEwMDc3MzMzS0VHSTlaRzBXUDU4JmVuY3J5cHRlZEFkSWQ9QTAxMTk4NTMzODZTRjZPSjlPSFBHJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ https://www.amazon.com/MIKKUPPA-Universal-Pressure-Injection-Systems/dp/B07WWT8K5Z/ref=sr_1_1_sspa?dchild=1&keywords=MIKKUPPA+0-140PSI+Universal+fuel+pressure+kit&qid=1620839525&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFBTjQ5V0szVEpMSEUmZW5jcnlwdGVkSWQ9QTEwMDc3MzMzS0VHSTlaRzBXUDU4JmVuY3J5cHRlZEFkSWQ9QTAxMTk4NTMzODZTRjZPSjlPSFBHJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ
Old Jun 21, 2021 | 01:35 PM
Motorhead1's Avatar
I never located the correct adapter, so I had my friend take his rover to our local indy shop, they tested the fuel pressure and it only had 25 pounds. So my assumption that the cause of the hard/long starts and engine lean codes is the extremely weak fuel pump. This particular disco has been running on this fuel pressure for a few years...This disco has 237k on the clock, Im pretty sure this is the original pump, but not 100%
Old May 2, 2022 | 02:07 PM
Motorhead1's Avatar
Ok, so me being completely dumb on this subject, and confusing all of you when I started this thread searching for the correct adapter to screw my fuel pressure gauge in..... The valve I was trying to adapt my fuel pressure gauge to months ago was this green capped valve (complete with label tag??) that has to do with the evap emissions system, not high pressure fuel..... Now, that I have torn down my first Rover engine to do head gaskets, I now understand what goes where and how things are routed! lol. I didn't realize the correct pressure test valve port was on the fuel rail under the rear of the upper intake manifold. Sorry for being a dumb azz....anyway
back when I was trying to test the fuel pressure (unsuccessfully) on this particular rover, a friend of mine owned it. I had him take it to our nearest indy shop, they charged 50 dollars to give it a fuel pressure test, 25 pounds. I wish I would have submitted a pic of this valve earlier, you all would have fixed me.
jkid
Jul 18, 2019 04:16 AM
deer40111
Aug 23, 2018 06:57 PM
Toran
Jul 12, 2018 09:44 PM
jimvw57
Mar 14, 2014 12:28 AM
ESPN
Dec 4, 2013 12:13 PM
