Sponsored by: CARiD
HELP needed--CEL: Fuel Trim System?
Old Apr 25, 2011 | 10:03 AM
Boxer12's Avatar
Default HELP needed--CEL: Fuel Trim System?
Hi guys, I have a CEL and code says "Post Catalyst Fuel Trim System Too Lean Bank 2." Sound like anything which I can fix myself? O2 sensor or something need to be replaced? Thanks in advance for help.
2006 RR Sport Supercharged
Old Apr 25, 2011 | 09:24 PM
Sounds like a bad O2 sensor, I would replace both of the post cat O2's at the same time.
Amazon.com has good prices on O2's.
Old Apr 26, 2011 | 10:02 AM
Boxer12's Avatar
Thanks, I will give that a try and report results.
Old May 9, 2011 | 06:17 AM
Rovin4life's Avatar
actually I would take a large cylinder and wrap it with tape until it fits the diameter of of the intake hole and turn the vehicle on. If there is an air leak you will hear a noise of a slight squeal and where it is coming from it is the source of the vacuum leak.
xhevi
Jan 17, 2019 01:31 PM
gpelite
Sep 19, 2014 07:37 PM
thechapo
Mar 2, 2008 04:33 PM
thechapo
Sep 26, 2007 07:08 PM
97DiscoKid
May 30, 2007 04:07 AM
