Full power steering flush on Disco 2
Old Dec 13, 2018 | 07:14 AM
  #41
FirstRoverDisco's Avatar
So, I am going to tackle this (hopefully) Saturday morning because, for some reason, Oklahoma has decided to be 60 degrees this week. My truck originally had the ACE on it, therefore has the dual reservoir, but the po's put regular springs in the back. Should this change the way I attack this maintenance, or should I treat it just like the ACE was still in place?
Old Dec 13, 2018 | 08:49 AM
  #42
mollusc's Avatar
ACE is not SLS. ACE is an active roll system; SLS is the air shocks in the rear.
Old Jul 26, 2019 | 11:40 AM
  #43
Sailor012's Avatar
8th Gear
Default Thanks
Glad I came across this, I'll be doing this on Saturday. Been a land over owner now all of 3 days lol.
Love it ... so far 🤪🤪🤪
Old Sep 22, 2019 | 04:49 PM
  #44
05TurboS2K's Avatar
Just another thank you for this write-up.
Old Sep 23, 2019 | 07:25 AM
  #45
redrover75's Avatar
Does anyone have a sense of how many times, how much fluid it could take to flush a power steering system, non-ACE?
I ran 2 bottles through, 64 oz, the fluid is clear, but there is still a buzzing noise when I turn the wheel. I am inclined to believe I have a defective pump, but wanted to get a 2nd opinion. I have driven it quite a bit, hoping that time would allow it to settle also. Or, is the pump simply bad?
thanks,
Old Sep 23, 2019 | 07:59 AM
  #46
JUKE179r's Avatar
Did you turn the steering wheel from lock to lock to get the air out of the power steering system?
Old Sep 24, 2019 | 08:42 AM
  #47
redrover75's Avatar
Default flush
I did, lock to lock several times. Should it take much more than that? the noise does get worse when the steering is locked. I feel like I went at it a number of times, over the last couple months and it never gets better.
Old Sep 24, 2019 | 10:34 AM
  #48
JoJo The Giraffe's Avatar
Not sure if you need a new seal kit for the pump or a new unit. Though I have not used it, Lucas does have a power steering conditioner. If this does not work, I think its a new unit.
Old Sep 24, 2019 | 01:30 PM
  #49
redrover75's Avatar
Thanks, i ran some through initially, but it got flushed out in repeated flushings. i suppose i will give it one more try and then do a new pump.
Old Nov 17, 2019 | 11:03 AM
  #50
stefanas's Avatar
Thank you. Did this last weekend and worked great!
