Fuse 15 (cig lighter)
Old Sep 20, 2012 | 05:35 PM
Ozzy3313's Avatar
Default Fuse 15 (cig lighter)
Just got my 2001 disco II. I'm not very car literate but this forum is great and has taught me a lot already. Anyway, I'm trying to replace the #15 in the main fuse box under the steering wheel which powers the cig lighter and a few other things. Owner manual calls for a 20 amp fuse. Every time I put one it and start the car it blows the fuse. Any ideas?
Note- there was no fuse in the box when we got the car... Damage already done?
Old Sep 21, 2012 | 08:28 AM
Yes, you have a short in the wire harness to the lighter, quit replacing the fuse or, if you haven't done it already, you may burn up the harness.
Leave the fuse out and take it to a local shop to have them test and repair it.
Old Sep 22, 2012 | 12:02 AM
Seat heaters, vanity mirrors, lighter - you can unplug some of thse things to see if load changes, can test with an ohm meter rather than risking harness.
Old Aug 8, 2015 | 07:51 PM
Poggi's Avatar
7th Gear
My 20A fuse is in tact and the lighter still does not function in my 2002 LR Disco II.
I suspect this too could be a wiring issue.
Old Aug 8, 2015 | 08:52 PM
Externet's Avatar
Ozzy : peek into the lighter socket for bent of stuck anything in there.
With engine running, apply a voltmeter probes to the nibs at both sides of the blown fuse face (where the 20A marking is). If there is voltage, the next new fuse you put in will likely blow.
If there is an anomaly inside the lighter socket, it can be unplugged at its connector by its back before installing the next new fuse.
smoothb479
Dec 16, 2019 11:38 AM
moorebl
Aug 13, 2013 08:38 PM
1chance
May 28, 2008 03:26 PM
ajh
Sep 30, 2007 08:16 AM
thisisheaven
Jul 12, 2007 01:03 AM
