Gas flap button and window air leak?
Old Aug 15, 2006 | 11:39 AM
jase0063's Avatar
3rd Gear
Default Gas flap button and window air leak?
The button to release the Gas flap is not working anymore. I'm not even sure where to start. Any ideas?
Also, the rear passenger door seems to have an air leak that I can hear and feel while driving. I rolled down the window and noticed that inside the window the guide that the window runs up seems to stop about 4-5 inches from the top and I was thinking that was the problem. I checked the other window and it stops about 1-2 inches from the top. I'm thinking that the guides are slipping down into the door. Any ideas?
Thanks,
Jason
Old Aug 15, 2006 | 01:54 PM
Default RE: Gas flap button and window air leak?
Yes, sounds like you need to pull those guides back up. As for the gas door have you tested the power to the solonoid at the gas door, check your fuse?
Mike
Old Aug 17, 2006 | 10:00 AM
jase0063's Avatar
3rd Gear
I checked the fuse. Seemed easy enough with the label on the fuse lid, but how can I check power to the solenoid?
Old Aug 17, 2006 | 11:39 AM
ORIGINAL: jase0063
I haven't crawled under mine, but I am thinking you should be able to see a power wire to the solonoid, from under the truck. If so prob it with a test light while someone is pushing the button.
Mike
oilspotLR
Oct 25, 2014 01:02 PM
terryga
Sep 1, 2013 11:43 PM
Spencerfitch
Dec 2, 2010 04:01 PM
wilson96rr
Dec 20, 2009 03:26 PM
Disco2Guy
Jan 21, 2008 01:41 AM
