Gas pump clicks off at gas stations.
Old Mar 30, 2023 | 04:16 PM
BS50MGSXR's Avatar
Default Gas pump clicks off at gas stations.
So have read about putting injector cleaner into the vent lines near the gas filler neck. Are the two vents the smaller holes top and bottom of the filler neck?
Old Mar 30, 2023 | 08:13 PM
Extinct's Avatar
Usually it is not your truck, it is the pump, unless it happens on all of them.
Old Mar 30, 2023 | 08:58 PM
Harvlr's Avatar
https://landroverforums.com/forum/di...ittent-111773/
Here’s what the problem was on mine.
Old Mar 31, 2023 | 09:38 AM
ahab's Avatar
I've been having this same problem, admittedly intermittently, but I'm also getting a recurring P0455 and wondering if it's related to issues with the vent system. As a non-SAI it has the simpler vacuum EVAP test and I've swapped out both the purge valve and the vent solenoid (and of course the gas cap) but the problem persists. I've disconnected the canister connections and refitted them, and don't see any other problems with the visible connections so I think the filler neck itself is the next step. Thanks for the link Harvlr, that's great info. .
Old Apr 4, 2023 | 12:47 AM
BS50MGSXR's Avatar
Looks like the injector cleaner worked, pored down the two smaller holes that are top and bottom of the filler neck. Went back to the same gas station and was able to fill up.
Old Apr 4, 2023 | 10:06 AM
Harvlr's Avatar
Easier fix than mine was. Good news.
jigray3
Sep 4, 2012 02:07 PM
honda50r
Jun 13, 2011 05:58 PM
mag48
May 18, 2009 09:52 PM
malxspod
Sep 22, 2007 03:04 AM
arcone
Sep 10, 2007 10:53 AM
