Gasket - Inlet manifold
Old Nov 18, 2015 | 01:08 AM
2003DiscoAZ's Avatar
Default Gasket - Inlet manifold
Hello, I am reassembling a 2003 D2 and cannot remember what hose hooks up to this fitting. The fitting is to the right of a multiplug. I have attached a photo with an arrow pointing to the fitting. Please help! Oh, and another question while i'm here, lol, I have no idea how to hook up the two lines to the throttle body. What are these lines? And what are their sources?
Thanks!
Attached Thumbnails Gasket - Inlet manifold-unknown-inlet.png   Gasket - Inlet manifold-throttlebodyhoses.png
Old Nov 18, 2015 | 03:40 AM
batard's Avatar
All I can tell you for sure is that the arrow in the second picture points to one of the throttle body heater plate tubes, which carries coolant. I can't remember if the one pointed to is the return or the delivery tube, though I'm not sure direction of flow matters.
Old Nov 18, 2015 | 04:56 AM
DII's Avatar
DII
It connects to the left tube of the throttle heater plate tube.
Old Nov 18, 2015 | 12:11 PM
Thanks, I am aware that the tube connects to the throttle body, just not sure where the other end of the tube connects to and guessing it is the radiator or the coolant overflow box? Could you tell me what it is connected to on your truck?
Thanks
What does the other end of the hose connect to, coolant overflow or radiator?
Old Nov 18, 2015 | 12:22 PM
WNYErikDiscoII's Avatar
Former Sponsor
Looking at the motor, the tube to the right connects to the coolant reservoir tank, hose part # is PCH000420
The tube to the left goes to the top of the plenum part # PEH101540
Old Nov 18, 2015 | 12:24 PM
mln01's Avatar
The outlet indicated in the picture of the upper intake manifold connects via a hose to the throttle body heater, as others have said. It doesn't matter which side of the TBH it is connected to but the standard setup is for it to connect to the left-hand side nipple on the TBH as viewed from the front of the truck.
The other nipple on the TBH connects via a short length of hose (maybe 2") to the nylon pipe that runs to the coolant reservoir.
Old Nov 18, 2015 | 02:09 PM
batard's Avatar
Others have already given the right answers, but roversnorth.com's diagrams can be helpful in situations like this: Discovery II Engine Top End - Rovers North - Classic Land Rover Parts
You can also always look at the shop manual.
Old Nov 18, 2015 | 07:58 PM
Thanks guys this is a big help, but I have read that the throttle body connectors can be bypassed is this true? Seems like a much better solution especially since i'm out in the desert where low temps seldom go below 50 Fahrenheit during winter nights. I think the bypass is just plug the plenum coolant line into the overflow source but let me know if this is ill advised.
Old Nov 19, 2015 | 09:19 PM
ATLDisco's Avatar
delete the throttle heater.
I'm in scottsdale, mine is gone, no problems at all.
If i lived in flagstaff I'd keep it.
ngarover
Dec 19, 2010 04:35 PM
rtonder
Freelander
Dec 4, 2010 11:10 PM
autopia
Jul 30, 2010 11:12 AM
roverdude09
Oct 11, 2009 11:36 PM
matthiasm
May 7, 2007 04:43 PM
