Gasket Sealant Advice
https://www.zoro.com/permatex-rtv-si...cADQ&gclsrc=ds
This is my favorite gasket sealant....for water pumps, tappet covers, intake manifold, etc.
Head gaskets shouldn't need any sealant. But, check...I've seen some head gaskets that do need a small dab around coolant ports...but this is unusual.
Brian.
Brian.
My understanding is that head gaskets should go on DRY, or maybe with some Permatex Copper Spray a gasket. I'm debating myself to go dry or copper.
As for other places, Right Stuff Gasket maker is popular. I also ordered myself a tube of Hylomar PL32 Aerograde for the bottom end and front cover.
The three sealants called for in the manual and substitutes...
STC 50550 -> Loctite 5900 or Right Stuff
STC 50554 -> Loctite 648
STC 50552 -> Loctite 243
Also Permatex High Tack Spray (the pink stuff) to hold valve cover gaskets in place is a good idea.
