Gear Box
Old Dec 30, 2008 | 04:54 AM
skikatana's Avatar
7th Gear
Default Gear Box
Have a 94 automatic and the gear box for positive traction and low high jumped out of gear and will only go into positive traction low or high. I can't get it back out of that setting at all and into just HIGH. any ideas?
Old Dec 30, 2008 | 08:09 AM
Default RE: Gear Box
Your linkgae is seized up.
Crawl under the truck and spray the linkage with a penatrant/lubricant and keep trying to move the lever.
Old Dec 30, 2008 | 08:17 AM
discoxd's Avatar
so what you are saying is that you can only get it to go into high range with the transfer case locked? no low range and no unlocking the transfer case?
Old Dec 30, 2008 | 11:20 AM
skikatana's Avatar
7th Gear
It only goes on the DIFF side in High and Low. Which means whenever that side is engaged the light on the dash pops up and tells you all four wheels are locked and driving at the same time. It will disengage to neutral but will not go in the far right side High or low.
Old Dec 30, 2008 | 03:44 PM
tomfraser's Avatar
for now, so you can drive around go under the car and removed the pin holding the linkage to the transfer box, then use a 13mm wrench to turn the bolt that the linkage goes to counterclockwise
then work the linkage bar back and forth till it comes free.
Old Dec 31, 2008 | 11:13 AM
ORIGINAL: skikatana
Did the t/case make any grinding type noise when this happened?
Do it make any noise while driving in High Lock?
wickham
Jan 8, 2007 08:26 PM
ant996
Defender
Sep 14, 2006 05:03 AM
Grtis1
Aug 7, 2006 03:32 PM
99Landrover
Mar 15, 2006 11:08 PM
richukbrb
Mar 14, 2006 12:34 AM
