gear oil
Old Nov 25, 2008 | 03:06 PM
discoxd's Avatar
Default gear oil
what is the recomended oil or whatever to use in my transfer case and front and rear diffs? plannin on changin them all tonight probably...
________
ROLL A JOINT
Old Nov 25, 2008 | 03:10 PM
AK Rover's Avatar
Default RE: gear oil
85w140 full synthetic for the differentials. Not sure about the transfer case though. May be the same but I doubt it.
Old Nov 25, 2008 | 03:17 PM
discoxd's Avatar
i had heard that you shouldnt run synthetic if your over like 50,000 miles because it make leak through the seals... but if its the same consistency, just a different chemical composition it really should affect it whether its dino oil or synthetic, right?
________
Hairy ***** Webcam
Old Nov 25, 2008 | 03:44 PM
Disco2Guy's Avatar
I use Mobil1 75W-90 in both diffs and the t-case.
Old Nov 25, 2008 | 04:00 PM
llesra's Avatar
cheap conventional 75w-90 or 80w-90 in the diffs and redline shockproof heavy in the t-case
Old Nov 25, 2008 | 04:14 PM
discoxd's Avatar
i'm gonna swing by the parts store after work and scope the selection and i will let you guys know what i get and how it works out...
________
Abigaillx
Old Nov 25, 2008 | 05:26 PM
Rover says synthetic, I go with the 85W/145 for much quieter gears.
Old Nov 25, 2008 | 07:43 PM
Full synthetic 85w-140 in both diffs and t-case. Your truck will be much quieter, and happier. Using full syn will also improve your MPG.
Old Nov 26, 2008 | 08:01 AM
discoxd's Avatar
stripped the threads on the t-case drain plug...[:@]
________
Los angeles dispensaries
Old Nov 26, 2008 | 07:50 PM
DOH!! How did you do that?
bcolins
Jun 10, 2011 11:36 PM
kpl1228
Mar 26, 2011 06:19 PM
mwindth
Dec 21, 2010 08:28 AM
Lee1140
Dec 1, 2009 10:17 AM
