Gear Oil and Automotive grease
Old Sep 26, 2008 | 10:24 AM
theworks001's Avatar
Default Gear Oil and Automotive grease
I bought some Gear Oil Mobil85w-140 for my Differentials. about how much should i put in each one of the Diff. Also Is this hard to do I also bought a manual pump because i heard its easier that way.
I bought some Mobil Synthetic grease for the bearings. Is this ok or do I need regular grease.
thanks
Old Sep 26, 2008 | 10:33 AM
Default RE: Gear Oil and Automotive grease
You can use the grease for your u-joints, everything else is sealed.
As for the gear oil, 1.8 quarts for each diff and 2.2 quarts for the t/case.
Old Sep 26, 2008 | 10:39 AM
Fill the diffs and transfer case until the gear oil starts to come out of the fill hole.
Replace fill hole and you are good to go.
That grease is perfect.
You will need 8 quarts to fill everything.
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
skatelove303
Sep 3, 2011 04:54 PM
cardocuk
Off Topic
Oct 28, 2008 01:34 PM
bigugly82
May 25, 2007 12:00 PM
