gear oil,,,refresh my memory
rave is on my other laptop with bad keypad,,,
how much oil for the diffs and trans case?
doing the diffs this weekend with a oil change. and i cant remember how much i need for the diffs and T-CASE.
gonna be a chore with one arm in a sling.
thanks mike,
i never use standard oil in anything. always always synthetic in everything =)
i have to see what i have in my shop. i believe i have 5 to 7 qts of valvoline synthetic gear oil in my shop. not sure on the viscosity thought. i know its most likely a 75/90 cause i had a bunch of it from when i did the gearbox on the 308. i always buy lots when i find a good sale on oils and lubes.
i was planning on doing the T-case but i might wait till later when i can have a extra set of hands to help out.
i had 5 qts in the garage.
so i did the diffs. it was valvoline synthetic 75/90. went pretty easy. small hand pump i bought at the parts store is always a lifesaver and even more so with one arm in a sling.
sale on mobil 1 synthetics. 5 qts of any weight plus mobil filter for 29.99. heck of a deal. +1 qt at the sale price. so i got my mobil 1 10/40 high mileage and 2 gallons of peak 50/50 mix for $10. and as always a bottle of water wetter.
all went well and i even managed to not break the plastic fill plugs on the diffs.
coolant tomorrow.
next is T-case and tranny. then belt and power steering fluid and the 60k will be done.
coolant tomorrow.
luxury1
Dec 3, 2008 07:09 AM
