Gear whine normal?
Gear whine normal?
Seems like the front diff or maybe the tranny whines... It's not loud, but you can def hear it, comes from just under and forward of the gear shifter. Is a little whine normal, I know my mustangs rear end has a decent amout of whine so I wasn't sure. Also what do you guys use for tranny and diff fluids? Do you add anything special? Thanks alot!
RE: Gear whine normal?
Truck looks good with the lights. If you are wanting extra light at night you might consider replacing your headlight elements with the 80/100 watt bulbs from Hella, I think that was the brand I used. Anyway, factory bulbs are rated at 55/65 watt, I believe and boy what a difference they make. These are not the real brite white replacements, they burn at the same light range as regular bulbs but go alot further down the road.
They are about $12 a piece and you can buy them from Expedition Exchange on the web.
Mike
Mike
