Gearbox change
Old Dec 11, 2009 | 06:30 PM
antunes's Avatar
4th Gear
Default Gearbox change
Hi,
I have a Disco 200 Tdi '93 and big gearbox problems...
I was offered a gearbox of a Range Rover Classic 88'.
Does anyone knows if it's possible to change one for the other ?
Are they compatible ?
Does anyone already made a similar change ?
Sugestions wellcome.
Regards,
Antunes
Old Dec 11, 2009 | 10:14 PM
LRScott's Avatar
Is yours a manual or automatic? The automatic transmission is the same on the Discovery I and Range Rover Classic. What year is your discovery?
Old Dec 12, 2009 | 02:05 AM
antunes's Avatar
4th Gear
Hi,
It's manual as well as the Range Rover.
My Disco is from 1993 and the Range Rover from 1988.
Regards,
Antunes
Old Dec 12, 2009 | 02:15 AM
LRScott's Avatar
I know the automatic transmission is the same on both disco and rr classic. I have not been able to find any information about the manual transmissions though. Have you tried the service manual?
Old Dec 12, 2009 | 07:48 AM
antichrist's Avatar
They are probably both probably LT77's, which were first used about in about '83 and last used in '94. But the vehicles being at the beginning and end of the production years one or the other may not be.
However, there were a number of improvements made to the LT77 during their lifetime and your Disco would have the "new and improved" model. So you'd actually be going backwards as far as reliability is concerned.
If I were in your position, I'd look for a good used R380. If you're in the UK maybe check with one of the transmission specialists like Ashcroft. I think they will sell you a rebuilt R380 using your LT77 as a core, albeit with a surcharge.
Old Dec 12, 2009 | 09:07 AM
antunes's Avatar
4th Gear
Hi,
Thanks for the sugestion.
I'm from Portugal, so buy a gearbox in UK and send it to Portugal and send back the old one to UK it's not easy and cheap...
If I was at UK everything would be easier
One of my other problems is €€€€
For the moment I will try the old LT77 from the Range Rover as it costs me nothing and if does not work ... well I will try to get another one but will have to wait some time....
Many Thanks
Antunes
hman
Jul 8, 2012 08:11 AM
collin Barrows
Aug 28, 2011 07:13 AM
96p384.6
Sep 14, 2006 01:48 PM
freeranger
Mar 29, 2005 06:03 PM
