Gearing Question
whowa004 (03-01-2020)
tires are 305/65/18 - roughly 34’s
i would like to try 4.11’s with these tires or 35’s with the ratio. I drive pretty slow, but I do cover a lot of distance, & I think it can be a little better balance
The 4.43’ are 7x31 - gives a little lower range & stronger setup then the 4.11’s - I wanted it for slower pace /crawling.
Just checked and Ashcroft has 4.37s so that sounds like a nice compromise if I do go to 35s or stick with the 33s. I don't need to drive fast but it would be real nice for a better crawl ratio and hopefully go over 40mph over the passes here with the pedal to the floor (very disheartening to be flooring it and watch the speedo continue to drop lol)
Excellent to hear. I haven't driven a stock D2 as mine the PO had 265/75/16 on it when I purchased so if I can run 35s and get back to that point at least I'd be pretty happy.
