Geeze...The 3 Lights...TC, ABS, HDC&^%$
Old Jan 9, 2007 | 01:24 AM
newBrover's Avatar
Default Geeze...The 3 Lights...TC, ABS, HDC&^%$
I just had new brakes installed 45 days ago. New pads, discs, all okayed by my local "rover guy." They were a bit squeeky at times, but I was told that was just one more rover thing.
He says it's probably just a matter of cleaning the wheel speed sensor. So, what say you? Is this simply a matter of replacing the pads to genuine Rover pads and cleaning the wheel speed sensors? Does that even sound like a logical proposal?
This frick'n truck is killing me!(*($^(&$#(&
Old Jan 9, 2007 | 11:19 AM
Default RE: Geeze...The 3 Lights...TC, ABS, HDC&^%$
What brand of pads and rotors did your mechanic use, this is important find out?
Also ask him if he used any brake sound deadening material material on the back of the pads backing plates?
Brakes are not supposed to squeak, especially on Rovers cause they will trip the trio of lights. Sounds like you mechanic missed something or used the wrong parts and should fix the problem.
Mike
Old Jan 9, 2007 | 02:46 PM
loic's Avatar
ORIGINAL: Disco Mike
Mike
I need to get my front rotors replaced and I'm thinking about doing it myself, which brand are you talking about ? anything I need to know before I order parts and do it myself ?
Old Jan 9, 2007 | 06:21 PM
Front brakes are easy to do, have you found any place to buy good quality rotors and pads? How maqny miles on your truck?
Mike
Old Jan 9, 2007 | 07:19 PM
loic's Avatar
Mike
it has about 78K miles. I bought it used back in september, the front rotors are shot, when I brake i have to pump once the pedal to get a good feeling. nothing special about those brake system ? I change brake rotor/ pads and did a lots of mechanic on cars and truck and do all my service on my bike but never with a land rover.
Old Jan 9, 2007 | 07:23 PM
loic's Avatar
from autozone : BECK_ARNLEYBrake Rotor $110.00
Old Jan 10, 2007 | 01:04 AM
newBrover's Avatar
Disco Mike,
I'm a regular contributor to a cycling forum. I'm comfortable being thesageexpert there, but you are certainly the guru on Discos here, so I applaud your willingness to share your experience with this forum. Kudos. Got that out of the way.
So, my brakes have a tendency to squeel sometimes. It's weird. Sometimes I can go days with quiet brakes then all of the sudden they screach like a banchee. If that alone caused my lights to trip, is that a sign of expensive repairs or is it a matter of new pads, a bit of wheel sensor cleaning and then the lights go off? There's no dust to speak of. He assured me he used the proper pads. He seemed aware of potential problems with using pads containing too much metal which by his accounts "contaminates" the magnetic wheel speed sensor.
We'll find out. On thursday I bet he nails me for another repair bill. He seems fair enough but new pads and a cleaning seems too easy for a Rover.
Anyway, thanks Mike for all the help.
Old Jan 10, 2007 | 12:10 PM
Call me and lets talk, I think I can point you in a direction.
Mike
303-862-7680
Colorado
Old Jan 10, 2007 | 01:24 PM
blake989's Avatar
I'm no help here (I've done the same things you have), but if its any consolation to you, I've had an '03 Disco since about August and those three lights followed bythe dreaded ding-ding-dingare the bane of my existence! If/when you find the root of your problem, please post back and let me know too.
Old Jan 10, 2007 | 04:26 PM
loic's Avatar
ORIGINAL: blake989
It's probably not related, but last saturday I was on my way to Death Valley and those 3 lights came on and the bling bling thing, I stoped at a gas station to kind of see what was the problem and at the same time check fluid level, I was low on oil , about 2 quarts low, I added the oil , start the truck again and the light were gone . I drove over 300 miles on that day and the 3 lights never came back on.
