Getting back door panel off.
Old Dec 23, 2014 | 11:59 AM
cappedup's Avatar
Default Getting back door panel off.
I'm looking to turn my spare wheel bracket over. That's the way to get the oversize tire to fit on there, right?
After realising the nuts arnt captive on the back of the door (curse), I snapped two out of three of the little plastic studs holding the interior panel on. So stopped.
Wasn't using a panel popper, but was being very careful with a big screwdriver.
Is it the cold? Fragile. Is there a technique I'm missing? Are they expendable? Like Rambo in Rambo II.
Old Dec 23, 2014 | 12:49 PM
ZGPhoto's Avatar
It's probably the cold, but honestly those things just always break. I usually end up with 3 or so broken each time I take a panel off, even with a panel popper
Old Dec 23, 2014 | 02:18 PM
cappedup's Avatar
Done.
Seems after a cup of tea I got a better break/not break ratio. Broke 4 in total. Not bad out of the 12 or so it needed to get access to the nuts. Panel went back on just fine.
Had to hack a bit out of the bracket for the rear wiper arm. Guessing that's normal?
Old Dec 23, 2014 | 07:42 PM
cybercop's Avatar
Looks nice.
Yes, hacking a piece out of the mount for the rear wiper is normal.
a good source for the push clips is
Land Rover DISCOVERY1 Tailgate Trim Panel Retention Clip Repair Kit DKP5279L X20 | eBay
BTW, do those wheels rub? Look pretty big and you don't seem to have a lift.
Old Dec 23, 2014 | 11:25 PM
cappedup's Avatar
Originally Posted by cybercop
Looks nice.
Yes, well they used to. I had to 'adjust' things slightly. Mainly remove the front flap part of my running board, and trim the back of the plastic bumper. They were fine, till I turned the wheels.
When I hit a decent bump the rear sometimes catches. But that is all now.
A lift is looking inevitable.
https://landroverforums.com/forum/di...ed-just-70992/
cobbcj7
Sep 30, 2014 10:38 AM
jpluncford21
Oct 17, 2011 09:45 AM
hallfleming
Jul 29, 2011 05:14 PM
Freelander02
Freelander
May 14, 2008 03:58 PM
