Getting code P0171, but not 0174
Old Feb 22, 2017 | 02:01 PM
LR03NJ's Avatar
I know how hard to remove those stuck sensors. No matter how much force you try to get those loose, it wont budge. But all the time i get it out. Lots of pb blaster, o2 rsensor removal tool, a large hammer and a pipe extension. Little by little.
Its also a good idea to het it from local auto store since its guaranteed. No waiting time to ship back and wait until return from online stores. AB prices might be expensive but it works for me for a long time until I replaced with Bosch and replacing them more often.
Aboit the picture. It usually burnt but not that bad. Im not sure if theres a way to test them or probably torch them until it hit a certain degree to see if sensors are working.
Old Feb 22, 2017 | 05:41 PM
Luckyjayb's Avatar
Originally Posted by mln01
The upstream sensors you should find at AutoZone, O'Reilly, NAPA, Advance, Pep Boys, etc. will more than likely all be the Bosch 15175 in a Bosch box.
most off em sell both the upstream and downstream sensors and that way you can swap out. If you have an advance auto, you can order online and pick up in store and they usually have a 15% to 20% off coupon on their front page if you do it that way. The AB ones are the walker o2 sensors that only have a 90 day warranty
Old Feb 23, 2017 | 09:11 PM
Jsivey's Avatar
So I finally got the other O2 sensor loosened up. Went to a muffler shop and they lifted the car up, put a crows foot on it and had it loose in 5 minutes. Will get the codes read again tomorrow and find out if it's the sensor that's bad.
On a side note, the guy told me that my catalytic converter was clogged, and it needed to be replaced. My question is, is there a way to clean it out like a radiator flush? If so, is it worth the trouble? Or should I just buy a new one from AB (or some other place)?
Old Mar 18, 2017 | 08:57 PM
Joelhimself's Avatar
Did the o2 sensor end up fixing your problem?
Old Mar 21, 2017 | 01:10 PM
Jsivey's Avatar
Maybe? I changed both upstream O2 sensors out, but that was back when it was throwing 1170, 300, and at least 2 30X codes for misfiring cylinders.
I have since taken off the Intake Manifold and replaced the coil packs (never had been done), spark plugs (not done in 100k miles or so), and the wires.
Still have an 1170 code that could be an O2 sensor that is faulty or it could be a crack at the weld spot from the pipe to the cat. I am traveling today, but when I get home tomorrow I'm going to smoke test the exhaust and look for the crack. I've read that this is a fairly common problem.
Doesn't really answer your question, but I went crazy last Saturday and changed all the plugs, wires, coils as well as oil, filter and diff fluid. So I'm assuming between the O2 sensors and the new plugs/wires/coils something got it working better.
brirsl
May 4, 2014 04:23 AM
richief556
May 17, 2013 07:18 AM
kfox77
May 18, 2009 09:24 PM
Charles68
Apr 2, 2008 01:37 PM
dbhook2
Jul 2, 2006 10:49 AM
