Getting Comical, I rev my engine and now no rpms and battery light is on.
Old May 9, 2010 | 10:26 AM
jarivera's Avatar
I have a DISCO II 2001 Land Rover and have recently replaced the Crank Sensor. When it is not functioning properly, your engine will stop running, and after a few minutes or hours you might be able to turn it on again, but then again, it will turn off.
One thing I learned through this experience is that not all Diagonostic Troubleshooting Code (DTC) readers have a code to diagnose the problem. However, one way to know that this might be caused by a faulty crank sensor is to see your tachometer (RPM needle), and if it is not working, (which is your case) there you have the likely cause of your suffering.
Please, respond and let me know how you eventually solved your problem.
Thanks.
José Antonio Rivera
Puerto Rico
Old May 9, 2010 | 11:33 AM
Spencerfitch's Avatar
Well my engine runs fine.. I'm on my way to pick up a alternator from a junk yard if it's still there.
And I tested tge wires, no outpt
Old May 9, 2010 | 03:37 PM
Alright new alternator in and it runs great. Whats wrong with the old one? How much will it take to fix?
Old May 9, 2010 | 04:42 PM
http://cgi.ebay.com/alternator-regul...item4a93e058ee
Old May 9, 2010 | 04:44 PM
Or buy one of these.
http://cgi.ebay.com/ebaymotors/Land-...Q5fAccessories
bballjames
Nov 27, 2012 11:46 PM
JumPeR04
Aug 9, 2012 03:37 AM
gwhiz101
Aug 29, 2010 08:48 PM
free_kid
13
Feb 3, 2010 12:56 PM
stokiemike
Dec 17, 2007 11:26 AM
