getting lift and bigger tires
Old Feb 9, 2009 | 07:14 PM
herblatham's Avatar
Default getting lift and bigger tires
getting a 2inch suspension lift and moving up to 235/85/16 tires. Wanted to know if i would need to do any trimming to stop the wheels from rubbing. Taken me forever to finally put the lift and tires on it, and i'll be sure to put some pics up,lol.
1998 Land Rover Discovery LE
134.000 miles
Old Feb 9, 2009 | 07:28 PM
llesra's Avatar
Default RE: getting lift and bigger tires
usually the rear quarter panel will have to be trimmed and steering bump stops adjusted
Old Feb 9, 2009 | 07:33 PM
herblatham's Avatar
steering bump stops? how is that done?
Old Feb 9, 2009 | 07:38 PM
llesra's Avatar
there is a large nut in front of the swivel *****. turn the steering wheel all the way to one side and you will see it making contact with the axle.
Old Feb 9, 2009 | 07:42 PM
herblatham's Avatar
what do i need to do to correct it, so it isn't touch the axle when i turn the steering wheel
Old Feb 9, 2009 | 08:35 PM
discoxd's Avatar
no the nut touching the axle is your bumpstop... turn your wheel with the bigger tires in place until they contact your control arms, then turn it back just enough to not touch the control arms... now with the tires amost but not quite touching the control arm adjust the steering stop nut until it contacts the axle... therefore stopping your tires from rubbing your control arms...
cst756
Apr 23, 2008 10:16 AM
Elhoff
Nov 22, 2007 09:39 AM
Blizwinter
Freelander
Aug 30, 2007 09:42 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Randy Lover
ROAMING WITH FRIENDS
24
Jan 31, 2007 06:38 PM
