Getting to the zerks on ujoints
Old Jan 30, 2016 | 12:11 PM
batard's Avatar
Default Getting to the zerks on ujoints
My standard grease gun nozzle has a hard time fitting over the zerks on ujoints because the knuckles(?) are blocking the way. Should I file down the sides of the nozzle? Is there a smaller version?
I've looked on some other forums and people seem to suggest dropping the shaft to grease it, which is not that hard but still a PITA for something so simple.
Old Jan 30, 2016 | 03:04 PM
Alex_M's Avatar
You've still got to drop it to grease the centering ball either way.
Old Feb 2, 2016 | 05:02 AM
Scout_Beagle's Avatar
I bought a second grease gun fitting and took it to the belt grinder and thinned down by creating two flat parallel sides. Works great for me.
Old Feb 2, 2016 | 05:11 AM
drowssap's Avatar
yes, but as stated earlier you have to drop it to grease the centering ball
Old Feb 2, 2016 | 10:17 AM
jamieb's Avatar
Question: I still have the original front prop shaft (going to get a replacement soon). On the original, does it have a centering ball grease fitting requiring it be dropped? Or is this just on the replacement shaft? Thanks.
Old Feb 2, 2016 | 10:24 AM
drowssap's Avatar
just replacements, the oem does not have a way to be greased, hence the problem
psykokid
Oct 22, 2011 07:16 PM
DDP
Jan 31, 2009 06:13 PM
applejack
Sep 8, 2008 07:20 AM
Ranchrover
Aug 13, 2008 04:08 PM
jyoung
Jun 7, 2008 07:20 PM
