Ghost in the Machine?
Old Jul 11, 2008 | 05:37 PM
okdiscoguy's Avatar
Default RE: Ghost in the Machine?
ORIGINAL: gonesouth
ORIGINAL: Spike555
So your stereo is working now? Recharge your A/C first, then check the blower. Door lock actuator, www.roverlandparts.com.
If it needed a recharge would the blower motor cycle with it?
You need a new fan speedswitch. I am guessing it mostly does it on high speed. Newt time it stops, touch the switch. If it comes back on, there you go...
Bad news is that the switch isn't sold by itself. Look for the assembly on e-bay. You can also take the switch out of the rear air control and put it in the front.
The only other possibility is a loose connection to theresistor pack-highly doubtful.
Old Jul 11, 2008 | 05:51 PM
http://www.roverlandparts.com/index....amp;ProdID=640
Lord Wert
Jun 17, 2013 06:09 PM
Street Wolf
Mar 16, 2012 08:38 PM
bigtimemcc
May 20, 2010 09:40 PM
Torancis_LR
ROAMING WITH FRIENDS
Jul 19, 2009 11:43 AM
Panama Jack
Oct 11, 2007 12:29 PM
