Glass 03/4 lenses
I know what mean about the wife "if you've got time to 'play' around with your cars you've got time to do this or that" how many time have I heard that said I'd like a dollar for every time
PS. the hot summer sun and road grime together with the halogen bulbs is the worst thing for crudding up your polycarbonate headlamps. Consider replacing the halogen bulbs with LED's which emit far less heat.
Just did mine
I had some fogging especially at the top of the lens. I used a 3M kit which had 2 levels of dry sanding disks followed by 3000 grit wet sanding and then a compound to finish it off. I then covered them with a 20% blackout film and they look great. Since it was the first time I used the film I got a few imperfections in it but it is easy enough to replace. I am hoping the film will protect the lenses from grit an UV. Looks so good I plan to do the tail lights next.
By the way, Jnj, that looks great. I'm glad you were able to clean them up so well.
Photo Added
Re fogging of the facelift headlamps, this is also exacerbated by the heat generated by the halogen bulbs (lamps) and maybe using LED or HID LED lamps instead should reduce this fogging to the ploycarbonate lenses.
I used the 3M kit also, pure magic. I used a sealer to finish the paintwork and headlamps which is great.
