Glass 03/4 lenses
Old Mar 15, 2015 | 04:47 PM
Jnj's Avatar
Jnj
Started with 800 finished with 2000 grit. Sprayed with a gloss clear with uv protection
Before
After
Will probably do a compound and seal once I've finished the conversion ( or when my wife gives me more time )
Old Mar 15, 2015 | 05:47 PM
OffroadFrance's Avatar
Before
After
Looks good, it'll last you another 11 years till it needs doing again
I know what mean about the wife "if you've got time to 'play' around with your cars you've got time to do this or that" how many time have I heard that said I'd like a dollar for every time
PS. the hot summer sun and road grime together with the halogen bulbs is the worst thing for crudding up your polycarbonate headlamps. Consider replacing the halogen bulbs with LED's which emit far less heat.
Old Mar 15, 2015 | 06:13 PM
Jnj's Avatar
Jnj
Will be doing projectors once Inhave completed the conversion. I just want to get everything cleaned up and installed first.
Old Apr 5, 2015 | 04:56 PM
Herb's Avatar
Default Just did mine
I had some fogging especially at the top of the lens. I used a 3M kit which had 2 levels of dry sanding disks followed by 3000 grit wet sanding and then a compound to finish it off. I then covered them with a 20% blackout film and they look great. Since it was the first time I used the film I got a few imperfections in it but it is easy enough to replace. I am hoping the film will protect the lenses from grit an UV. Looks so good I plan to do the tail lights next.
Old Apr 5, 2015 | 11:53 PM
Alex_M's Avatar
Got any pictures?
By the way, Jnj, that looks great. I'm glad you were able to clean them up so well.
Old Apr 19, 2015 | 10:43 AM
Herb's Avatar
Default Photo Added
Here is a photo of the job.
Attached Thumbnails Glass 03/4 lenses-img_0515.jpg
Old Apr 19, 2015 | 05:10 PM
Re fogging of the facelift headlamps, this is also exacerbated by the heat generated by the halogen bulbs (lamps) and maybe using LED or HID LED lamps instead should reduce this fogging to the ploycarbonate lenses.
I used the 3M kit also, pure magic. I used a sealer to finish the paintwork and headlamps which is great.
Old Apr 21, 2015 | 11:23 AM
dgi 07's Avatar
After
Those are some snazzy socks. Do you have a matching snuggie to go with it?
Old Apr 21, 2015 | 05:23 PM
Jnj's Avatar
Jnj
Just a matching polo and loafers
Old Apr 21, 2015 | 06:11 PM
abran's Avatar
Whats all this talk about projectors? Can you still keep the light sealed with original screw caps after adding them? I am interested but currently my daughters has HID with holes in the caps for pigtail and water finds its way into the lights.
