Glowing Ground wire
Old Sep 28, 2015 | 12:19 PM
haleyrover's Avatar
Default Glowing Ground wire
Changed the oil pump gears on my 2004 DII. Everything went smooth. Put it all back together and hooked the battery up. Ground wire screw on the alternator bracket started glowing .. wires started smoking. I unhooked the battery pretty fast. Any ideas to trouble shoot?
Old Sep 28, 2015 | 12:26 PM
TOM R's Avatar
There's a ground wire on the alt? Think you mean the charge wire unless d2 is way different then d1
Alt grounds through the brackets
Double check you did not crush any wires on reassembly
The wires to alt should be big one = battery +, small = ign +?, and a tach lead iirc
Old Sep 28, 2015 | 06:10 PM
OffroadFrance's Avatar
Have you checked the main engine earth/ground cable or maybe forgotten to replace it. The electricity will find the path of least resistance or an alternative path.
It also may be your regulator in the alternator has gone bust by coincidence.
Old Sep 28, 2015 | 07:13 PM
haleyrover's Avatar
thanks. Just my luck. I'll double check all of the wiring and cross my fingers on the alt
zracin
Jan 23, 2024 10:19 AM
mark wilson
Sep 20, 2011 05:54 PM
RROJ
Jul 24, 2011 07:59 AM
Rioja Red
Oct 23, 2007 09:56 PM
kcirtap
Sep 26, 2007 09:39 AM
