HVAC Question 03' Disco
Old Apr 9, 2015 | 05:47 PM
d4stir's Avatar
6th Gear
Default HVAC Question 03' Disco
I hope someone out there has encountered this issue... Actually is a Land Rover you probably all have. I started encountering intermittent starts and stops with my AC Unit it would randomly turn on and off. Then it just stopped running. I ran the diagnostic procedure and am getting code 21 and 22 which according to RAVE are Sunlight Sensor left and right output open. I read somewhere that this is more typically a resistor pack issue. Any thoughts?
Old Apr 10, 2015 | 10:40 AM
Fast951's Avatar
First step is probably to check Low side pressure to make sure there's enough refrigerant in the system. If it's low the compressor will not run. There is a pressure switch as a safety mechanism to stop compressor from seizing due to no lubricating oil flowing through the hoses. If pressure is low you likely have a leak. Problem areas for o-ring failure I have found are top side of compressor (both High side and Low side) and the dryer, located behind the front grille.
Old Apr 10, 2015 | 10:49 AM
drowssap's Avatar
does it get cold and not cold or does it turn on and off
Old Apr 16, 2015 | 07:40 PM
d4stir's Avatar
6th Gear
Default Nothing runs
Nothing runs. The fan will not run and the only thing working is the display for the HVAC System. A couple of months ago (during the winter) the heater would turn on and off intermittently for say 3 seconds on 5 minutes off. Now nothing works..
Old Sep 29, 2015 | 09:00 AM
cappedup's Avatar
That would be my guess. It's more likely a blend door issue.
Read the RAVE section about it.
Grrr. done it again. Posted in the wrong thread.
Ignore. Move along.
comleader
Jul 9, 2013 06:24 AM
Classic74
Mar 15, 2013 08:57 AM
blast20
Jan 10, 2010 07:05 AM
ScottinNJ
Oct 28, 2007 09:02 AM
distributorguy
Jul 8, 2007 03:59 PM
