going to get new tires in the morning.
Old Jan 29, 2009 | 10:27 AM
roverboy's Avatar
Default going to get new tires in the morning.
I will be getting new tires tomorrow and want to get 245 75 16 will they rub I have no lift on my truck,and will the truck sit a little higher? 1996 SE 122,100
Old Jan 29, 2009 | 10:32 AM
hazletbassist89's Avatar
Default RE: going to get new tires in the morning.
They may rub a little bit under heavy articulation but if it's even a problem you can probably trim back just a little bit in the wheel wells and be fine. The truck will pretty much look the same, maybe an inch higher.
Do you off road at all? At your mileage your suspension is probably drooping quite a bit, so if you do any off roading you should consider a new suspension setup. With just a 2 inch lift you can go to 32" tires and be sitting much higher, if that's what you're looking for.
Old Jan 29, 2009 | 11:07 AM
roverboy's Avatar
Well I decided to stay with the 245 70 16 that I currently been running it looks nice and sits pretty well too.I did some researching and found out 245 75 16 will not rub with a d2 but a little with a d1 .
Alex_M
Nov 22, 2018 12:53 AM
TATZOO
Jun 10, 2013 05:22 PM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
fazooley
Mar 29, 2006 01:28 AM
