Good battery slow cranking before start
Old Dec 5, 2018 | 04:03 PM
Fizzbiz's Avatar
Default Good battery slow cranking before start
The battery checked out good but when I turn the key to start, no cranking for 1 to 2 seconds than slow cranking like a near dead battery for a second or two than the starter takes off and it starts normal. All the,lights are bright and no dimming like a low battery. It has not failed to start... yet
Old Dec 5, 2018 | 04:38 PM
The Deputy's Avatar
Clean your ground cable terminal, where it connects to alternator bracket (known fail area). And all battery terminals. If it still persist, starter would be next suspect.
​​​​​​​ Brian.
Old Dec 6, 2018 | 10:08 AM
CollieRover's Avatar
This could be a failing starter. Does the starter sounds healthy?
Also, get under and take a look at the XYZ/Nuetral Safety Switch. If the front lower rivet tops are popped off, this can cause intermittent no start, and is rebuildable.
Old Dec 6, 2018 | 05:21 PM
Fizzbiz's Avatar
Closer inspection I think it's the starter. The solenoid clicks then gives off an electrical scorch smell that I had not noticed before. Thanks for the feedback.
Old Dec 7, 2018 | 06:17 AM
On Best4x4’s recommendation I put in a Partsplayer from Amazon. Less than a 100 bucks, made may old starter sound like a sick constipated elderly cow, and has worked in -10f weather without a hesitation. Really happy with it.
To remove you’ll want standard metric hex sockets. I don’t remember the exact size.
NZDiscoowner
Jul 17, 2017 05:28 PM
Snowdog
Apr 15, 2014 08:45 AM
firstgeer
Defender
Jul 26, 2013 08:26 AM
mojosh
Sep 12, 2012 06:59 PM
baddiscoII
May 2, 2011 08:16 PM
