Good investment? Suspension galore!
Old Oct 29, 2009 | 04:36 PM
skatelove303's Avatar
Default Good investment? Suspension galore!
http://toddcosuspensions.com/2cospsulikit1.html
2" Coil suspension spacers... Do they hold up okay?
i just want to throw them on there on my stock shocks and springs to be able to get some bigger tires on... Mostly for looks... once in a while go mudding...Eventually i would want to throw on 2" Springs and Shocks over the coil spacers to get a total of 4" of lift, With that do i need to do anything to the driveshafts or brake lines?
Thanks guys!
Old Oct 29, 2009 | 06:31 PM
gilder's Avatar
Don't use spacers - you are wasting your time. If you want a 4" lift you will need to replace the shafts and other things - very expensive. Stick with a 2" OME or RTE spring lift.
Old Oct 29, 2009 | 06:59 PM
Ah, yea thats what im hearing, I want to fit 265/75/16s... just like yours actually lol But man i cant afford 1500 dollars in one sitting ahah.
Old Oct 29, 2009 | 08:55 PM
JavaRacer's Avatar
my 2" with shocks, coils and a steering stabilizer was under $800
Old Oct 29, 2009 | 10:48 PM
oysterhead's Avatar
hes probably adding in new bigger tires.
Old Oct 29, 2009 | 11:41 PM
Yea im adding in a set of 265/75/16 BFgoodrich All terrain TA KOs
Old Oct 30, 2009 | 03:10 PM
Rover Curious's Avatar
If you can't afford it now then save your money. Get the suspension first and then the tires/wheels later. If you're gonna do it, do it right. If you do it wrong, it'll end up being more expensive in the long run from stuff you have to fix.
Old Oct 31, 2009 | 06:40 PM
Only thing is i need tires, And i need tires that will hold up to the rocky mountain winter... The ones i have right now are bald, So its either i do it or i dont...
Old Oct 31, 2009 | 07:18 PM
Got to go to coils and shocks, check out Lucky 8 for their $628 set of OME's.
Old Oct 31, 2009 | 08:26 PM
Crap disco mike, You just killed my excuse thats holding me back from buying the lift kit... Being able to find one online... Darn... Well if i buy it il have to install in myself Anybody whos got a good how to video would be awesome!
The Cisco Kid
Aug 19, 2013 12:42 PM
indiefantv
May 6, 2013 12:45 AM
phil29
Sep 25, 2011 07:28 PM
karyllemia
Sep 6, 2007 09:25 PM
ajh
Aug 22, 2007 05:30 PM
