good stock cam for a 4.6 ?...
Old Jan 31, 2021 | 12:35 PM
cfz2882's Avatar
Default good stock cam for a 4.6 ?...
...or very mild upgrade. Don't know if my cam is worn,but just thinking about options if I find mine worn when the engine is apart(118,000,runs great,usual noises,RH head gasket leak to outside reason for repair...) thinking about checking the timing chain and oil pump too. found some new cams made in England and I suppose some of the US cam companies have some offerings for this engine. 2003.
Old Jan 31, 2021 | 01:25 PM
jastutte's Avatar
i went with a Crower Level 2 Camshaft when i did mine in my '04. noticeable difference in throttle response.
if you're already in there i would definitely upgrade the cam.
Old Jan 31, 2021 | 03:04 PM
CollieRover's Avatar
My Turner short lock came with the HP180 Sportstorque Cam from Kent Cams. I love it. Idles fine, and is noticably better.
Old Jan 31, 2021 | 11:06 PM
Art H's Avatar
No CEL on those cams? I was looking for something to up the power a bit.
Old Feb 1, 2021 | 07:27 AM
jastutte's Avatar
no CEL.
Old Feb 9, 2021 | 06:51 PM
cfz2882's Avatar
thanks guys,ill look into those when the time comes
Old Feb 9, 2021 | 07:27 PM
cvhyatt's Avatar
I've been pretty happy with my Kent Cam. Its plug an play and gives you 25 more horses Kent H180 Camshaft Sports Torque – Turner Engineering
Old Feb 9, 2021 | 08:41 PM
whowa004's Avatar
About to be dropping the hotter of the two crower Level 2 cams in both my Discos.
ImQuattro
Jan 19, 2024 02:54 PM
Speedsterguy
Dec 8, 2022 09:29 AM
Llamasayswhat
Sep 16, 2018 11:14 PM
Fast951
Aug 29, 2016 06:21 PM
05gixxer
Jul 20, 2011 07:38 PM
