Got my 04 CDL shifter but no nipple link..
Old Jun 13, 2013 | 10:46 PM
bballjames's Avatar
Originally Posted by Okie Rover
Thanks everyone, just got done installing it. If it wasn't so hot out it wouldn't have been bad. But heat makes small things into big annoyances. BUT its installed thats all that matters. I took a linkage off the original transfer case shifter and rigged it to work on the nipple. Worked really good actually. At first the light on the dash came right on no problem when i tested it a few times. But now sometimes when i engage it the light doesn't want to go off when i unengage it. And its flickered a couple times so im assuming thats just the switch acting up?
It's a good possibility I just replaced mine. Couple weeks back. The way the switch is designed it would be easy for it to get stuck in the "engaged" position. Also sometimes it just takes a couple yards to disengage.
Old Jun 14, 2013 | 02:07 PM
Okie Rover's Avatar
Update. So driving more after the install the light was flickering on and off constantly as I hit bumps. Well I got underneath and had a friend engage and undo it a few times and came to realize its moving just enough to lock and unlock it but the light switch seams like its borderline when u in engage it. So I moved the lever over the rest of the way from underneath drove home and no more light. I need just a little more tension on the cable to move it all the way back. Is there a way to do this?
turbodave
Mar 29, 2019 07:22 AM
suntattoo80
Aug 9, 2011 06:13 PM
Analogkid
Oct 28, 2010 05:38 PM
Jupe209
Sep 5, 2010 11:46 PM
Disco2Guy
Nov 27, 2007 04:54 PM
