Got a temperature gun -- Measured the cooling system
Well you have never had it put together enough to bleed it properly... Slow down and do things one at a time then see where you are at. I've had temps reach 215 with a good stat when it was not fully bled. So employ some patience here and give it a try. It may take a few days of topping through the bleed screw to attain perfection.
No fiddling around for hours/days parking uphill with the moon in the waning gibbous phase at midnight trying to get the air out of the cooling system.
I got mine done in 15 minutes with my air lift kit.
Probably done about 3 cycles now of starting the truck up, letting it get up to 195 and then turning it off and letting it sit. Add a tiny bit of coolant via the bleed screw when things are stone cold -- still overheats.
One of those air lift dealios would be awesome but.. not something i can use / buy at the moment.
