Got a temperature gun -- Measured the cooling system
Old May 12, 2018 | 03:42 PM
  #71
redwhitekat's Avatar
Mine opened at 195 in a pot of water put it in the truck and my temps were 215
Old May 12, 2018 | 04:01 PM
  #72
Dave03S's Avatar
Well you have never had it put together enough to bleed it properly... Slow down and do things one at a time then see where you are at. I've had temps reach 215 with a good stat when it was not fully bled. So employ some patience here and give it a try. It may take a few days of topping through the bleed screw to attain perfection.
Old May 12, 2018 | 04:53 PM
  #73
Twix's Avatar
Took me 3 days to fully bleed my system. There still might be air in it, but I'm happy with my temps. Bleed, bleed, bleed.
Old May 12, 2018 | 05:28 PM
  #74
razorkill12's Avatar
I use an air lift...no more air pockets...best tool purchase ever...
Old May 12, 2018 | 07:17 PM
  #75
JUKE179r's Avatar
Exactly!!!!
No fiddling around for hours/days parking uphill with the moon in the waning gibbous phase at midnight trying to get the air out of the cooling system.
I got mine done in 15 minutes with my air lift kit.
Old May 13, 2018 | 08:27 AM
  #76
shanechevelle's Avatar
Funny what havoc an air bubble can wreak.
If your heat isnt HOT it needs to be bled....ON A HILL
Old May 14, 2018 | 06:49 AM
  #77
Saturnine's Avatar
Probably done about 3 cycles now of starting the truck up, letting it get up to 195 and then turning it off and letting it sit. Add a tiny bit of coolant via the bleed screw when things are stone cold -- still overheats.
One of those air lift dealios would be awesome but.. not something i can use / buy at the moment.
Old Jun 9, 2019 | 04:48 PM
  #78
jastutte's Avatar
did you ever get this figured out?
dealing with a similar issue on one of my '04's.
Old Jun 9, 2019 | 05:44 PM
  #79
Saturnine's Avatar
Yep, for me the temp sensor from L8 was bogus. Bought one from AB and everything was dandy
Old Jun 9, 2019 | 09:06 PM
  #80
jastutte's Avatar
you're talking about the temp sensor on the manifold outlet?
