Got the valve covers off, what do you think?
Replacing the coil packs and throttle body heater today so I decided to just do the valve cover gaskets and have a look while I'm in there. The right side seems a little dirtier than the left? What can be used to safely clean the springs and rocker arms or just don't worry and let rotella do it?
Carb cleaner will clean the oil off the arms, but it really does not matter. its on the outside of the rocker arms. No real benefit to the engine... other than to look good. Someday when you drop the oil pan to replace your oil pan gasket, you will see all the brown coating. Its fine. Just run Rotella and all will be good.
Dirty? This is dirty....
And after working on it I wonder if I will ever stop smelling like Rotella, SWMBO said she was going to spray me with Lysol...
With four bolts you can have those rockers off as an assembly, mine feel gritty when operated, so I will soak them.
Be sure all your PCV components and passages are clear.
Thanks for the pic Buzz. With 153k miles this truck it just continues to amaze me how well kept it must have been. Wow I feel bad for the guy who thought he was getting one over on me, by selling it for $3500 with an undisclosed oil leak.. That was fixed with a $12 bottle of white sheppards rear main
Rebuilt heads?
It is common to remove the rocker arm assembly before hot tanking heads. Your heads appear to have been tanked at some period, probably when the head gaskets were replaced...lol? Do you know if it has been built in the past. That would explain the clean heads and discoloration on the rocker arm assembly. Never seen a engine with 153k miles that looked that clean. Even without sludge buildup, a amber hue is common, yours look like new aluminum. Nice engine!
Hi Mike, I did check out the link which went right to "Setting Tappet pre-load step by step ". Not going into the valley gasket I figured that wasn't for me. Of course now that I have everything back together I re-read the entire page and saw the section for "Identifing worn Rockers" which is what I now think you were trying to alert me too! It'll have to wait till next time.
