Grease joints
Old Mar 17, 2013 | 01:38 PM
redwhitekat's Avatar
Default Grease joints
Was under the truck today doing a lube job a few questions was going to grease my Tom woods shaft but only saw 2 grease nipples on either end of shaft ? Is that All there is ? Also did not find any nipples for steering joints or any other nipples ?? Is there more
Old Mar 18, 2013 | 09:04 AM
antichrist's Avatar
Steering ball joints don't have them from the factory, and many aftermarket ones don't either.
If it's a TW front there are are 5, one for each u-joint, one for the slip joint and one for the centering head which you probably can't get to without dropping the shaft at the output.
Old Mar 18, 2013 | 10:14 AM
Ill have to look again but I didn't see any other grease nipples just 2 on either end of shaft ill take some pics next time and share
Old Mar 18, 2013 | 10:25 AM
The slip shaft may not have a grease fitting but a plug, if that is the case, buy another zerk and install it.
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
Spencerfitch
May 14, 2010 06:28 AM
lipadj46
Oct 3, 2009 11:01 AM
Darover
Apr 2, 2008 08:06 PM
