Great... throwing some codes and running rough.
Old Aug 13, 2013 | 09:52 PM
jeffh's Avatar
here you go
Magnecor 80242 Ignition Cable Set 8mm Rover 99 04 | eBay
Old Aug 13, 2013 | 11:02 PM
Snafu / Disco Fries's Avatar
I saw those, but the 5 day handling time doesn't make sense. I need something to get here by Friday. Also, I noticed AB stopped carrying these and only carry the 7mm ones now. I'm wondering if there has been an issue with them. If indeed better, why would an expert in rovers stop carrying them?
Old Aug 14, 2013 | 06:44 AM
jeffh's Avatar
maybe because AB wants more repeat customers. I would not use the 7mm. Can you find the 8mm and expedite the shipping.
Old Aug 14, 2013 | 08:36 AM
Not seeing any but will look
Old Aug 14, 2013 | 09:24 AM
jeffh's Avatar
SNAFU,the link i sent you. The location of the shop selling them is Farmingdale Nj, that cannot be very far from you.
Old Aug 14, 2013 | 12:38 PM
No, but has hubbub about 5 day processing, might be in a different warehouse, etc. Will see if I could call them.
Old Aug 14, 2013 | 12:54 PM
And what does the "screw on" mean? Looking at STI and others and I see that. I thought they just push in.
Old Aug 16, 2013 | 06:20 PM
vicky8264's Avatar
Default check engine light: code P2098
I have a 2006 Range Rover 4.2 motor. Check engine light P2098, also had low fuel pressure, had new fuel pump, light came back on, new o2 sensor, light came back on, any suggestions?
Old Aug 16, 2013 | 06:26 PM
The 7mm Magnacors only carry around 35,000 volts , the 8mm wires carry 55,000 volts and handle more then 100 additional degrees of engine compartment temp.
Old Aug 18, 2013 | 09:02 PM
Ordered the 8mm. Should come tomorrow. Will do the method without removing the intake. Just need some smaller hands now lol
