Greg Davis Rear Bumper
Old Mar 25, 2013 | 11:05 AM
ZGPhoto's Avatar
Default Greg Davis Rear Bumper
Hey all,
Thought I'd make a thread showing some photos of what is entailed with a GD rear bumper install in case anyone was thinking about it. I'm by no means a mechanic, and most everything I install isn't done using all the materials .
Too much overhang ruins the departure angle.
Bumper is bent, hangs far too low.
This area needs to be cut, preferably smoother than I did. However, I will be installing a plastic trim strip that takes care of any inaccuracy while still looking good.
The "2" in this image represents what I bent with the previous bumper, needs to be hammered down.
The "1" in this image is what needs to be hammered in for the GD bumper to mount correctly. You could cut it off or hammer it in.
Yes it looks terribly, but cutting off that much right before the rear silencer is one of the better decisions I've made with the vehicle. It's not louder at all, the engine does not have a high enough output to necessitate that awful extension hanging down.
This is the piece that mounts inside the wheel well. It's mounted with 3 bolts to where the mudflap bracket mounts.
Here you can see I pulled the quarter protectors out a bit before welding them on the rear bumper, I wanted a little more tree protection.
The height difference and departure angle difference is insane. This is the highest clearance rear bumper you can get for these vehicles.
For the lighting I decided to route my directional wires to the reverse plinths and install amber bulbs. I then routed my reverse lamp wiring to the rear work lamp. In the future I may set up a relay for the system.
The Hella worklamp I bought is amazingly bright and wide for being so small. WORK LAMP HELLA ULTRA BEAM CLOSE RANGE , 90656 - Land Rover Parts | Rovers North
And after a day of off-roading with it yesterday I'm extremely happy with the modification. I didn't get hung up once, and it did great at pushing little trees away from the rear quarters.
Cheers,
Zack
Old Mar 25, 2013 | 11:26 AM
Good write up, I had the same damage to my Disco 9 or so years ago and built a bumper that is very similiar to yours, including improved clearance and lighting.
People who light wheeling without so much rear damage should consider doing what you have shown.
Attached Thumbnails Greg Davis Rear Bumper-dscf0060.jpg   Greg Davis Rear Bumper-dscf0059.jpg
Old Mar 25, 2013 | 11:31 AM
ZGPhoto's Avatar
Yeah Mike I really liked yours, if I was able to do fabrication I would have made one to replicate it. Yours looks very strong and well made.
Old Mar 25, 2013 | 11:33 AM
Thanks, it sure stopped me from doing any more damage. Have fun wheeling.
Old Aug 13, 2013 | 10:03 PM
ZGPhoto's Avatar
Just an FYI - he is selling one of these for $525 SHIPPED, anywhere in the states right now. Last one he has in stock currently. Greg is a great guy and someone you should support! This bumper has saved me over and over, I've yet to hit/snag it on something.
Old Aug 14, 2013 | 11:11 AM
acamato's Avatar
What are you doing with the old bumper?
Nevermind, Just saw in one of the photos above, that its bent petty good.
Old Aug 14, 2013 | 11:13 AM
ZGPhoto's Avatar
I sold the HD rear bumper long ago, as well as the plastic factory one prior to that.
goatman
Mar 30, 2020 08:54 PM
Jcbe34
13
Apr 3, 2014 09:04 PM
aftermath431
Sep 23, 2013 08:17 AM
bcolins
Jun 22, 2013 08:55 PM
A5scott
Aug 26, 2012 09:13 AM
