Sloppy wheel....front end issue...
Old Feb 12, 2007 | 06:37 PM
84 GRANDSPORT's Avatar
4wd High
Default Sloppy wheel....front end issue...
I can move my steering wheel about a inch back & forth with out the truck (97 Disco with 127k) moving...What is the possible issue? Where should I start? Thanks in advance!
Old Feb 12, 2007 | 07:01 PM
geoman's Avatar
Default RE: Sloppy wheel....front end issue...
At that mileage, the truck most likely needs:
1. All tie rod ends in the steering gear replaced
2. The steering box "pre-load" adjusted
3. Both panhard rod bushings replaced ( the panhardroddetermines thelateral location of your front differential housing)
Geoman
www.eurotekapg.com Land Rover Hard Parts delivered to your door
"serving the do-it-yourself Land Rover owner/enthusiast"
Old Feb 12, 2007 | 07:20 PM
4wd High
ORIGINAL: geoman
Geoman
ouch....that is alot of stuff....I honestly bought the truck to turn a profit soI want to spend as little as possible...I found a service book in the car stamped by rover all the way to 90,000 miles....I am hopeing some stuff was replaced? Can you tell me what steering box pre poad ajustment means? Is this something I can do? Thanks in advance.
Old Feb 12, 2007 | 07:30 PM
You don't buy Rovers to sell them and turn a profit. Sounds like you are about to make a major investment in your truck.
Mike
Old Feb 12, 2007 | 07:33 PM
geoman's Avatar
Look on rangerovers.net , as there may be a printedprocedure there for adjusting the pre-load. Essentially -- there is a threaded shaft with a lock-nut that protrudes out of the top of the steering box. With the wheels off the ground and pointed straight ahead, you slacken the locknut while holding the shaft with a allen wrench. Then -- you turn the shaft clockwise a little at a time, and then turn the steering wheel through it's full range both left and right. Repeat -- until you detect a "SMALL" amount of resistance at the extreme left and right position. Then tighen the lock nut and once more-- turn the wheel through its full motion in both directions to make sure there is no binding.
Information offered with no liability on my part, you understand. You are just trying to tighten up some normal slop in the steering box. Sometimes it works, sometimes the box is too worn out.
Geoman
Old Feb 12, 2007 | 07:43 PM
4wd High
ORIGINAL: Disco Mike
Mike
Mike I actually sold two rovers for profit in the past 3 months...I made $1400 on a 96 & $2400 on a 99 I sold last week....I bought this 97 for $2200...It makes $ even with the issues it has trust me...I might just bring it to the auction or ebay it (if ebay I will disclose the issue as I am a honest guy) if the front end is too bad....the other issue is the heat ( another post I made) & lastly a tranny line is leaking which set me back a whole $49.57...Hopefully the job goes smooth...sometimes those lines like to twist....Anyways thanks for letting me post here!
Old Feb 12, 2007 | 07:47 PM
4wd High
ORIGINAL: geoman
Geoman
Thankyou so much!Hopefully this will help the condition! Nice to know as I like buying Rovers in the winter...So far I have donewell selling them as there is not 20 of them in the paper like alot of other cars I sell....Anyways thanks again for the tip & yes I understand there is no liability on your part.
s10lowrider1994
Jan 7, 2013 09:41 PM
spicer
May 6, 2012 11:18 AM
RjBu
Mar 1, 2011 10:31 AM
salve7
ROAMING WITH FRIENDS
Mar 1, 2010 07:39 PM
sloppyjoe
Sep 17, 2009 12:23 PM
