Guys & Gals RockWare Front and Rear Pinion Guards Installed!
I got these in the mail last Friday. Finally got around to putting them on. The front needed a 2mm thick spacer to make it not touch the drag link.
$80 for the front
$60 for the rear
www.rockware.com
Hardware included looks like 3/16" steel.
Now Im ready for some hits.
Front:
![](http://img.auctiva.com/imgdata/1/3/2/8/1/7/9/webimg/485430637_o.jpg)
Rear:
![](http://img.auctiva.com/imgdata/1/3/2/8/1/7/9/webimg/485430605_o.jpg)
$80 for the front
$60 for the rear
www.rockware.com
Front:
Rear:
![](http://img.auctiva.com/imgdata/1/3/2/8/1/7/9/webimg/485430590_o.jpg)
My set are pretty old, so there's been a design change (based on your pictures). The rear I have has a flat length of metal from front to back, with support in the middle, to keep you from hitting the bolt heads (similar to the way the front is done.)
They're great for catching the grease coming off a leaky u-joint.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Yes decarr1971
You can barely catch the front of the of the diff guard in the first picture. Its a bolt on with two bolts. Its a D1 diff guard that I had welded in an additional 2 inches on the clamping ring. I bought them in a pair and sold the other on eBay for what I paid for both. About $65 on eBay. I never saw a reason for the rear diff guard unless you backed into a rock, I guess anything can happen but seems less likely.
While my front diff guard is beat to snot, the rear has seen its fair share of hits. The last trail I ran a couple weeks back took a shot at the guard when I slipped off a rock with the back tire. I noticed the white residue still on the guard as I crawled around the Disco on Sunday. It happens.
The front is certainly the big concern, but rear shouldn't be forgotten...
bosshogt
08-04-2011 12:49 AM
