Guys & Gals RockWare Front and Rear Pinion Guards Installed!
Old Jun 27, 2011 | 10:49 PM
bosshogt's Avatar
Default Guys & Gals RockWare Front and Rear Pinion Guards Installed!
I got these in the mail last Friday. Finally got around to putting them on. The front needed a 2mm thick spacer to make it not touch the drag link.
$80 for the front
$60 for the rear
www.rockware.com
Hardware included looks like 3/16" steel.
Now Im ready for some hits.
Front:
Rear:
Old Jun 28, 2011 | 10:22 AM
Banzai Jimmy's Avatar
My set are pretty old, so there's been a design change (based on your pictures). The rear I have has a flat length of metal from front to back, with support in the middle, to keep you from hitting the bolt heads (similar to the way the front is done.)
They're great for catching the grease coming off a leaky u-joint.
Old Jun 28, 2011 | 11:35 AM
dcarr1971's Avatar
Do you have a diff guard welded on the front diff? Couldn't tell from the picture...
If not, then you probably need them too. You don't want to be this guy:
Old Jun 28, 2011 | 11:56 AM
sloan74's Avatar
Nice boss!
Old Jun 28, 2011 | 09:43 PM
bosshogt's Avatar
Yes decarr1971
You can barely catch the front of the of the diff guard in the first picture. Its a bolt on with two bolts. Its a D1 diff guard that I had welded in an additional 2 inches on the clamping ring. I bought them in a pair and sold the other on eBay for what I paid for both. About $65 on eBay. I never saw a reason for the rear diff guard unless you backed into a rock, I guess anything can happen but seems less likely.
Old Jun 28, 2011 | 10:24 PM
yloDiscoII's Avatar
Very cool, didn't even know those things existed! Thanks for sharing.
Old Jun 29, 2011 | 01:26 AM
While my front diff guard is beat to snot, the rear has seen its fair share of hits. The last trail I ran a couple weeks back took a shot at the guard when I slipped off a rock with the back tire. I noticed the white residue still on the guard as I crawled around the Disco on Sunday. It happens.
Old Jun 29, 2011 | 09:50 AM
dcarr1971's Avatar
...never saw a reason for the rear diff guard unless you backed into a rock, I guess anything can happen but seems less likely.
I definitely agree that it's less likely that you'll whack the rear diff, but it's something I managed to do last winter. While climbing a steep, rocky, icy trail I ended up sliding backwards onto a large rock that gave my rear diff guard a pretty good shot. (How hard did it hit? I wasn't moving too fast, but it stopped the whole truck sliding backwards down the trail and took enough of the weight off the rear wheels that I couldn't get any traction with them.)
The front is certainly the big concern, but rear shouldn't be forgotten...
TopGunRover
Apr 4, 2015 04:26 AM
ATLDisco
Feb 19, 2012 09:40 PM
bosshogt
Aug 4, 2011 12:49 AM
Spike555
ROAMING WITH FRIENDS
Mar 21, 2010 03:07 PM
Our1stDisco
Mar 23, 2008 09:21 AM
