H E L P !!!! Disco wont stop rocking
Old Apr 12, 2007 | 12:19 PM
kraftwyrk's Avatar
8th Gear
Default H E L P !!!! Disco wont stop rocking
I need some help and advice...2000 Disco..88K ..just dropped a bundle on major brake and sensor work...was all good...for two days...out last night and SERVICE ENGINE light came on....also started to hear a loud thumping noise from the rear...along with this she is now rocking from side to side when I slow down...????? no issues over 35 mph but slow at an intersection and thump and rock...H E L P
Old Apr 12, 2007 | 01:00 PM
Default RE: H E L P !!!! Disco wont stop rocking
Drive it very carfeully back to how ever did the brakes and have them fix it. Did they use factory parts or aftermarket?
Mike
Old Apr 12, 2007 | 01:04 PM
kraftwyrk's Avatar
8th Gear
So you think it's a break issue??? I don't have the brakes applied when it happens..it will do it at a slow roll...
Old Apr 12, 2007 | 02:18 PM
Did this happen before you had the shop work on it, if so take it back to them.
Mike
Old Apr 12, 2007 | 09:37 PM
handsome rob's Avatar
You may have a seperated tire somewhere that creates the rocking motion. When you get at speed then it creates it's own vibration and would not be as noticeable. That or one of your wheels was not put on staright and creates the wobble. I am just throwing things out but they may be worth a try.
Old Apr 12, 2007 | 09:40 PM
piotrsuw's Avatar
Double check to make sure that they didn't forget to tighten the lug nuts on one of the wheels.
Piotr
Old Apr 13, 2007 | 08:07 PM
suntattoo80's Avatar
check the lug nut's then the swaybar link's link's will cause this issue verbatem
Old Apr 13, 2007 | 11:14 PM
If you are not familiiar with your truck, get it into a shop ASAP and have a mechanic check it before someone gets hurt.
Mike
Old Apr 17, 2007 | 12:23 PM
kraftwyrk's Avatar
8th Gear
Well guys I have the answer....took some time and did some research ..there are two hydralic stablizers mounted to the front and rear ....the bushings were missing so they kept trying to work with no resistance...got those replaced and all is good
Old Apr 17, 2007 | 01:16 PM
Are you talking about shock bushings or the bushings on your ACE rams?
Mike
aly
Aug 1, 2024 07:12 PM
disconic
Jun 4, 2016 02:57 AM
archaeology_student
Feb 18, 2016 10:36 AM
Nicholas Rowland Ellis
Mar 28, 2012 08:01 PM
phelps69
Nov 30, 2010 08:56 AM
