Half my windshield defrosts?
Old Oct 13, 2012 | 04:51 PM
suzukisam967m's Avatar
Default Half my windshield defrosts?
I see there are two plugs under the hood, so I'm assuming they are powered on each side. why don't I have power to the drivers side? when I hit it the passenger side clears instantly
Old Oct 13, 2012 | 05:16 PM
blamo's Avatar
I would try cleaning the plugs on both sides of windscreen ,then check fuses, relays.
Old Oct 13, 2012 | 06:27 PM
Bad relay or bad heating elements in the windshield, maybe they got damaged somehow?
Old Oct 13, 2012 | 07:22 PM
jafir's Avatar
Fuse would be my guess.
Old Oct 13, 2012 | 07:25 PM
I couldn't figure out which relay it is based on the rave, anyone know the relay and fuse locations
Old Oct 13, 2012 | 11:04 PM
jafir's Avatar
There is just one heated windscreen relay, R8 in the under hood box. But since there is just one, that's probably not your issue.
F7 is the left side fuse and F8 is the right.
Old Oct 14, 2012 | 12:27 AM
X2 with above, and each heated front screen has a different ground. With the ground loose you won't have heat on one side, even if fuse is OK. Since one clears, the relay is OK. Meter across both wires in plug to see if you have battery voltage. Ground comes from a header where other things find ground as well.
Old Oct 14, 2012 | 09:08 AM
Stone chip on one side will kill that side element, very common with most vehicles.
Old Oct 14, 2012 | 10:17 AM
I have a crack right behind the review mirror. I assumed because of that i wouldn't have a windshield heater at all, but where the largest part of the crack is the heater works just fine. I'll check everything and if it all checks out I'll assume nit' just the crack... crappy part is the passenger side clears...
Old Oct 14, 2012 | 11:55 AM
Also replacement generic glass frequently comes with elements, my Kia van needed new glass and it came as the heated version, installed $240.
