handbrake light flashing?
Old Nov 30, 2018 | 01:32 PM
RubyRoverD2's Avatar
Question handbrake light flashing?
my red handbrake light is flashing randomly while driving, i read fourms and saw that it could be low brake fluid or bad brakes, so i replaces disks and pads all around, and my brake fluid was at the full line, and the light went off and everything was normal for about 120 miles, now it back. any ideas?
Old Nov 30, 2018 | 02:14 PM
CollieRover's Avatar
How are the wires going to the brake reservoir cap?
Old Nov 30, 2018 | 02:48 PM
they look fine, and they're sturdy all the way into the harness
Old Nov 30, 2018 | 06:33 PM
Extinct's Avatar
Your brake fluid is low, when you go up a hill or down a hill the float triggers and turns on the light. You probably have the very very common leaking seal between the master cylinder and reservoir. wipe a finger on the master cylinder and i bet it is wet. You can order the seal kit, the seal is the same as some common audi models.
austinlandroverbill
Dec 20, 2018 11:32 AM
adamwest21
Jan 29, 2016 10:50 AM
Jason_B
Jan 4, 2013 12:26 PM
binvanna
Oct 23, 2012 07:07 PM
Trickymonk
Jan 16, 2012 07:28 AM
