Has anyone had a leak at the rear axle where the bearing sits?
Old Aug 25, 2021 | 03:11 PM
me 2's Avatar
Default Has anyone had a leak at the rear axle where the bearing sits?
I have diff fluid leaking out of the axle but can’t pin point the area it’s leaking from! It’s the pass side rear! Fluid is all over the inside of the tire. I replaced the bearings about 2 months ago. Pulled that specific bearing but couldn’t find anything out of the ordinary. Just wondering if that’s the only spot that could have a leak?
Old Aug 25, 2021 | 04:29 PM
The Deputy's Avatar
There's an o-ring on inner edge of hub.
9 times out of 10...vent is plugged. Remove vent tube and blow it out with compressed air.
Old Aug 25, 2021 | 04:35 PM
me 2's Avatar
The only o ring I’ve seen is the one on the bearing itself, slips into the axle Over the cv joint. I’ll check it out and the vent though, thanks for the info
Old Aug 25, 2021 | 04:45 PM
The Deputy's Avatar
This picture shows o-ring.
Old Aug 25, 2021 | 04:52 PM
The Deputy's Avatar
The front hub does not have an o-ring on hub housing, like rear. Yeah, there's a small o-ring on C/V shaft...but it has nothing to do with sealing fluid. Front axle has seals mounting in housing.
Old Aug 25, 2021 | 04:57 PM
me 2's Avatar
Yeah, I pulled that again but o ring looks good
Old Aug 25, 2021 | 07:38 PM
Daytoman's Avatar
Yup happened to me. Previous owner just replaced rear hubs. About 8 months after I bought Clarkson the passenger side started leaking.. replaced it and then the drivers side started leaking. Removed vent tube and traced it. PO had installed a wading kit so there was a lot of tube to clear. it was clogged.
Old Aug 25, 2021 | 07:55 PM
me 2's Avatar
The vent was clogged?
Old Aug 25, 2021 | 08:22 PM
Daytoman's Avatar
Yes it was plugged up. To make matters worse my vent tube runs up the rear drivers side corner. I had to undo it at one of the couplers and blow it out in two sections.
Old Aug 25, 2021 | 08:35 PM
me 2's Avatar
Wow, ok, let me try that
