Has anyone had a leak at the rear axle where the bearing sits?
Old Aug 27, 2021 | 03:48 PM
me 2's Avatar
So pulled the bearing again and didn’t see anything out of the ordinary but when I set the bearing down fluid came from between the bearing. Where the screw driver is pointing! Am I looking at a crap bearing? Also found that the vent tube is fine and is not clogged up.
Old Aug 27, 2021 | 04:00 PM
me 2's Avatar
Let me update on that last message! It actually looks like it’s coming from the abs sensor area.
Old Aug 28, 2021 | 03:50 AM
The Deputy's Avatar
Yeah, if it's leaking between two bearing pieces, flange and housing...could be bad hub...and not unheard of nowadays. But, l'm not seeing any o-ring in groove (arrow).
Old Aug 28, 2021 | 07:55 AM
me 2's Avatar
I had the ring off during the pic. I siliconed the holes that the abs slips into, gonna give that a shot before buying another bearing.
Old Aug 28, 2021 | 06:04 PM
me 2's Avatar
Okay, still leaking, time for a new bearing! : (
Old Aug 29, 2021 | 06:37 AM
The Deputy's Avatar
Sometimes, the little attachment on axle housing, where vent tube attaches, can rust closed also, so maybe take a look at that.
Old Aug 29, 2021 | 08:38 AM
Daytoman's Avatar
Both my hubs leaked from where you pointed out. On my hubs there was plenty of bearing packing grease on that flange, not just diff fluid. Again,I am pretty damn sure mine had to be at least partially, if not completely due to pressure buildup. But I have to admit, I think most of these hubs are pretty jenky.
Best bet on a leaky hub IMO, change them out and make sure vent hose is clear when you do it.
Good luck. you can see what I’m talking about. Yikes!
Old Aug 29, 2021 | 08:55 AM
me 2's Avatar
Yeah, I see what you mean. I’ll check the vent at the axle too! Thanks guys
Old Sep 5, 2021 | 10:33 AM
me 2's Avatar
Replaced rear bearing again and so far no leak! Thanks for all the help!🙂
jbullock78
Jul 1, 2019 06:21 PM
TheWhiteRover
Aug 16, 2014 08:20 AM
lost rover
Mar 31, 2013 09:41 PM
Spike555
May 27, 2009 07:32 PM
sanmigmike
Aug 24, 2006 03:37 PM
