Has anyone replaced Torque converter solenoid on Discovery 2?
D2 manual:
Trans manual:
Do you have any symptoms to warrant solenoid replacement? Can the code be cleared? Does it immediately return?
Not necessary to remove trans to replace.
P0741 * Torque converter lock-up clutch fault
May affect driveability.
The software has detected a potential problem with the torque converter system.
Cannot identify any symptoms associated with code appearing. It has appeared twice with over 100 miles between codes. Both times with heavy weather conditions (major snow storm and second time heavy rain). Tran fluid looks good in color aND level. My code reader says solenoid locked off. Replaced torque converter in 2013. Good to know that am not looking at pulling transmission. Thanks
marsyas
02-25-2021 08:11 AM
cobbcj7
12-13-2019 06:12 PM
